Get current template group and template in a plugin
Pv Ledoux's avatar
Pv Ledoux
14 years ago
Pv Ledoux's avatar Pv Ledoux
maybe I’m loosing my mind but I can’t find a way to know what is the current template group/template in a plugin.
There is nothing relevant in the Template class. It should be simple but…
Any idea are welcome!
Cheers!
Pv
the3mus1can's avatar
the3mus1can
14 years ago
You might be able to grab it out the $this->templates_sofar instance variable of the template class. Take a look at the fetch_and_parse method in the template class. Otherwise I do not think that there is a way to with the template class.
