Fieldtype requires Module during installation
John Morton's avatar
John Morton
14 years ago
John Morton's avatar John Morton
If you’ve got a module that requires an extension, you use ‘public $required_by = array(‘Module’);’.
I’m trying to get something similar with a fieldtype I’m working on. Basically, you must have the module installed to make the field type work properly, but I can’t get the same sort of installation that ‘public $required_by = array(‘Module’);’ provides.
Is there a way to make the installation of a fieldtype require a module?
Thanks.
Focus Lab Dev Team's avatar
Focus Lab Dev Team
14 years ago
Focus Lab Dev Team's avatar Focus Lab Dev Team
No, not currently. You can add some logic into your fieldtype install method to make sure the module is installed though.
