SafeCracker hooks
cfenwick's avatar
cfenwick
14 years ago
cfenwick's avatar cfenwick
I’m trying to make an extension that will do something after the user has submitted a safecracker form. I’ve created a hook on the safecracker_submit_entry_end and it triggers when the form is submitted, whether it has passed inline validation or not. How do I find out if the form has passed validation in my code? The documentation at http://ellislab.com/expressionengine/user-guide/modules/safecracker/development.html doesn’t mention this at all.
Here is the safecracker code:
{exp:safecracker channel="profile" return="/thank-you" id="publishform" include_jquery="no" author_only="no" error_handling="inline" .... }
Dan Decker's avatar
Dan Decker
14 years ago
Dan Decker's avatar Dan Decker
Hi cfenwick,
As I understand, you are developing an extension that listens for the safecracker_submit_entry_end hook, is that correct?
I would expect that the form would have passed validation if the hook is called, since validation happen inline with the SafeCracker form.
However, we don’t offer support for add-on development, we just aren’t set up to do so. To get you to the right audience, I’m going to move this into Development and Programming.
Cheers!
Bhashkar Yadav's avatar
Bhashkar Yadav
14 years ago
Bhashkar Yadav's avatar Bhashkar Yadav
The hook on safecracker_submit_entry_end will trigger if entries data has been saved passing the validation (inline).
cfenwick's avatar
cfenwick
14 years ago
That’s the problem I’m having, safecracker_submit_entry_end is triggering whether it has passed validation or not.
Bhashkar Yadav
14 years ago
are you setting the validation rule into safecracker tag
like
rules:my_field_name="required|min_length[5]"
try it, it may validation the inputs before triggering safecracker_submit_entry_end.
cfenwick's avatar
cfenwick
14 years ago
Yes, I’ve got them. here’s the full tag:
rules:title="required|min_length[5]"
rules:gp_practice="required"
rules:gp_email="valid_email|required"
rules:gp_address="required"
rules:gp_city="required"
rules:gp_postcode="required"
rules:gp_latitude="required"
rules:gp_longitude="required"
Rob Sanchez's avatar
Rob Sanchez
14 years ago
Rob Sanchez's avatar Rob Sanchez
You can see if validation passed by checking SC for any errors:
$validation_passed = empty($this->EE->safecracker->errors) && empty($this->EE->safecracker->field_errors);
if ( ! $validation_passed)
    exit("YOU FAIL!");
cfenwick's avatar
cfenwick
14 years ago
It worked! Thanks Rob.
