Onchange actions for custom entry fields
vaneone's avatar
vaneone
14 years ago
vaneone's avatar vaneone
Hello,
I am currently creating custom functionality within expressionengine to be able to cross-reference entry data with data from an external api
I created a custom field that will accept the id of the entity from the external api that the entry corresponds to
What I want to do is create an onchange event on my custom entry field that will accept a search term and run a search query against the external api and show an active list of results to choose from (like google search)
When the user clicks an entry in the list, I want the field to populate with the corresponding id
I have lots of experience with web development, and I already know how to handle all of the JS, but I am very new to EE and, after looking at the hooks documentation, I’m not really sure where I can add an event listener in an elegant fashion.
Maybe one of you EE-savvy folks can point me in the right direction?
Also, I would like to know where I can add script tags to the control panel’s header.
Any help is greatly appreciated.
Thanks -D
vaneone's avatar
vaneone
14 years ago
By the way I am running version 2.1.3
John Henry Donovan's avatar
14 years ago
John Henry Donovan's avatar John Henry Donovan
Hi vaneone,
We have a Development and Programming forum which is perfect for this type of question so moving this thread for you
This link may help. Now it is EE1.x and it doesn’t have anything to do with the final result you wish but the JS functionality it uses may help.
vaneone's avatar
vaneone
14 years ago
John,
Thanks for your reply!
There is some very useful information there, I think this is exactly what I was looking for.
I’ll post my own solution when I finish, I am pulling my autocomplete data with JSONP from external server
Thanks again!
v
