Looping through data using if and mod
Mat's avatar
Mat
14 years ago
Mat's avatar Mat
I’m trying to loop through entries and on every 5th one change a class in a li tag,if I use:
<?php
     for($i=0;$i<10;$i++){
<?php
     if($i % 5){
<li class="start">
    {title}
</li>
<?php  }else{ ?>
  <li class="end">
    {title}
  </li>
<?php } ?>
<?php } ?>
So basically this just doesn’t work :( I do get that it wont work with entries, it is a loop already, but how can I do the above in EE? Thanks
Mat's avatar
Mat
14 years ago
Mat's avatar Mat
ok so I figured I can use switch but how can I check the value of switch in a if statment.
the3mus1can's avatar
the3mus1can
14 years ago
You should not have to use a conditional:
<li class="{switch="end|end|end|end|start"}">
Focus Lab Dev Team's avatar
Focus Lab Dev Team
14 years ago
Focus Lab Dev Team's avatar Focus Lab Dev Team
Are you referring to EE’s {switch} tag? I’m not sure I understand the question - but you can use the {switch} tag like this:
<li class="{switch='one|two|three|four|five'}">
In a 10 entry result, that would print the word “one” on the 1st and 6th entry, the word “two” in the 2nd and 7th entry, etc.
That in mind, you can leave the first 4 empty to just have something printed each 5th entry:
<li class="{switch='||||five'}">
Edit: I forgot to hit submit then noticed you got an answer already 😊
Mat's avatar
Mat
14 years ago
Mat's avatar Mat
Thanks Erik & the3mus1can all working perfectly now.
