sql query for channel field image
stevo_s's avatar
stevo_s
14 years ago
stevo_s's avatar stevo_s
How do I get the file name for a channel image field {thumbnail} that is in a channel using sql query? When I look in SQL manager the image file appears like this in exp_channel_data field_id_6:
https://ellislab.com/asset/images/team-photo/13.jpg
the exp_channel_data channel_id is 3
Do I need to do a JOIN with exp_files - file_name ? ( I only want images from that channel 3 though).
I’m trying to grab the 4 last images posted to a channel - 1 per author.
this doesn’t seem to work:
{exp:query sql="SELECT file_name FROM exp_files
WHERE exp_channel_data.channel_id='3' LIMIT 4"}
{file_name} alt=
{/exp:query}
[Mod Edit: Moved to the Development and Programming forum]
the3mus1can's avatar
the3mus1can
14 years ago
You might want to look at this thread: Remove the filedir_1 from the start of the rendered sql call
stevo_s's avatar
stevo_s
14 years ago
Ok, thanks. Do you have to hard code the url to a file as {path= doesn’t seem to work as it put /index.php at the end ?
the3mus1can
14 years ago
You could use {site_url}.
stevo_s's avatar
stevo_s
14 years ago
thanks.
