logged_in_group_id Resulting In PHP String Instead of Integer
ROCKET MEDIA's avatar
ROCKET MEDIA
14 years ago
ROCKET MEDIA's avatar ROCKET MEDIA
Not sure why, but this won’t work…
$x = {logged_in_group_id};
but this will
$x = “{logged_in_group_id}”;
I figure, fine, ill just input it as a string and then to convert to a integer with this:
$x = intval(“{logged_in_group_id}”);
But this just returns nothing.
Not sure what’s up.
Victor Michnowicz's avatar
Victor Michnowicz
14 years ago
Victor Michnowicz's avatar Victor Michnowicz
Make sure you do comparisons with “==” not “=”.
Edit: Nevermind, I totally misread what you were trying to ask. You could try just using typecasting with (int). Maybe that will work for you.
ROCKET MEDIA
14 years ago
I tried the three variants:
$x = intval(”{logged_in_group_id}”);
$s = ”{logged_in_group_id}”; $x = (int)$s;
$x = ”{logged_in_group_id}”; settype($x, “integer”);
None of these work.
I have found, however, that they DO work if I replace {logged_in_group_id} with a normal integer… For instance – this works.
$x = intval(”1”);
I think this may be an expression engine thing?
Lisa Wess's avatar
14 years ago
Lisa Wess's avatar Lisa Wess
Mixing PHP and EE tags can be complicated. Why not simply use the full session class?
ROCKET MEDIA
14 years ago
I’m not too familiar with the session class. This doesn’t seem to be working.
<?php
$aRestrictedID = array();
$currentGroupID = $this->EE->session->userdata('group_id');
{exp:weblog:entries weblog="page"}
$aRestrictedID[]= 1;
{restrict_page}$aRestrictedID[]= {restrict_to_id};{/restrict_page}
{/exp:weblog:entries}
if ( in_array ( $currentGroupID , $aRestrictedID ) ) {
test
<?php
Lisa Wess's avatar
14 years ago
Ah, you’re on EE 1. try this instead.
ROCKET MEDIA
14 years ago
Fantastic! Worked great. Thanks 😊
Lisa Wess's avatar
14 years ago
My pleasure! =)
Manatax's avatar
Manatax
12 years ago
Manatax's avatar Manatax
THANK YOU!!!!!!
