Counting/switching inside template variables
rschmitty's avatar
rschmitty
14 years ago
rschmitty's avatar rschmitty
I’ve got 2 template variables that are tied to a 3rd party webservice (not channel/entries) and when I try {count} or {switch} it is always 1 or doesnt switch
{exp:mythirdparty:userinfo}
{first_name} {last_name}
{call_history}
{count} {call_date} {call_person}
{/call_history}
{transactions}
{count} {trans_date} {trans_amt}
{/transactions}
{/exp:mythirdparty:userinfo}
Every count is 1, which I’m assuming because there is only 1 userinfo record
Is it possible to count when looping in a nested tag or do you need to bake in your index/increment into the arrays
onewed's avatar
onewed
14 years ago
onewed's avatar onewed
Bumping this because I’ve not yet found a good solution other than rolling my own {index} variable into my custom loops.
For instance:
{workbook_entries}
  <h3>{entry_title}</h3>
  {if entry_index < 2}
    {entry_body}
{/workbook_entries}
I’ve looked at the switch tag which doesn’t appear to be appropriate since it’s meant for rotating through values.
the3mus1can's avatar
the3mus1can
14 years ago
Are you using $this->EE->TMPL->parse_variables() in your addon?
http://ellislab.com/expressionengine/user-guide/development/usage/template.html#parsing_variables_pair_vars
onewed's avatar
onewed
14 years ago
We’re using parse_variables, I just realized though that the {count} and {total_results} is only generated for the outermost array of the template variables. We might reorganize some calls to alleviate this issue or make use of some {embed} calls.
For instance this doesn’t create {count} for the inner array ‘articles’
$vars = array(
  array(
    'section' => 'foo',
    'articles' => array(
                    array('article_id' => 3, 'summary' => '...',
                    array('article_id' => 5, 'summary' => '...')
  array(.....)
template
{exp:our_call}
  Here are the articles for {section}
  outer count: {count}  {!-- this is valid --}
  <ul>
  {articles}
    <li>{count}: {summary}</li>  {!-- this is NOT valid --}
  {/articles}
  </ul>
{/exp:our_call}
This seems potentially like a bug, considering the fact that the array loop {articles} is parsed and therefore no reason it can’t have its own {count}, like we did manually. I can see a problem with variable name collision, but could be worked around by incrementing the count and total_results variables, like using {count_1} in the {articles}..{/articles} loop.
