Is there a way to set a flag or create a user-controlled variable in a channel entry?
txdigital's avatar
txdigital
14 years ago
txdigital's avatar txdigital
Is there a way to manipulate/create a variable in an entry? I’m using a plugin I bought but its not as robust I had wanted.
I’m supposed to use it like this:
{exp:member_categories:check category_id="1"}
//If True, shows this
{if no_results}
//If not true, shows whats in here
{/exp:member_categories:check}
But I want it to be able to check multiple category_id’s…That only checks one.
So I want to create a variable that sets $isitokaytoshowthis=1 if multiple category id’s are set to true.
Does EE allow something like this? I cant seem to use PHP in my wysiwyg editor to make variables, so im out of options.
