_ci_model_paths made protected - breaking AJAX Babble add-on
Developer Preview
Laisvunas's avatar
Laisvunas
14 years ago
Laisvunas's avatar Laisvunas
There was much talk about _ci_view_path making protected. Now it is made deprecated and set_package_path is being advised to use.
But I found that in EE2.2 another CI variable - _ci_model_paths has also been made protected and now it breaks my add-on AJAX Babble.
This add-on outputs this error:
Fatal error: Cannot access protected property EE_Loader::$_ci_model_paths in /home/admin/antiquityillustrated.org/eesys/expressionengine/third_party/ajax_babble/pi.ajax_babble.php on line 264
Is there a workaround? Or perhaps it is possible to make _ci_model_paths deprecated in the next build and introduce some substitution for add-on developers?
Laisvunas's avatar
Laisvunas
14 years ago
Hi again,
Nobody interested in EE v.2.2 breaking of add-ons?
I understand, that EE2.2 is released and dev preview program came to an end, but not everyone had time enough to test every add-on until June 22.
14 years ago
I’ll drop an email w/more details, but you don’t want to use _ci_model_paths- try reworking it with add_package_path instead. That workable?
Laisvunas's avatar
Laisvunas
14 years ago
Hi Robin,
Thanks for the suggestion.
My code which was broken by EE2.2 is this
if ( ! class_exists('Comment'))
   require PATH_MOD.'comment/'.'mod.comment.php';
$COMM = new Comment();
array_push($this->EE->load->_ci_model_paths, PATH_MOD.'comment/');
$COMM->insert_new_comment();
If I understood you correctly, it should be replaced by this code:
$this->EE->load->add_package_path(PATH_MOD.'comment/');
$this->EE->load->library('comment');
$this->EE->comment->insert_new_comment();
Unfortunately, this code does not work. I get this error message:
Unable to load the requested class: comment
14 years ago
We won’t discuss how long it took for me to spot the problem. Or the fact I had to ask Pascal. There… is no comment library.
I haven’t fully tested what you’re doing- but I can load the model via:
$this->EE->load->model('comment_model');
Hee- can’t believe we both missed it! That get things going?
Laisvunas's avatar
Laisvunas
14 years ago
Hi Robin,
This solved my issue.
Thank you very much!!!
14 years ago
😉 Glad that did the trick. No doubt it will help someone out in the future as well!
