Call an Extension on Every Page Load
blendimc's avatar
blendimc
14 years ago
blendimc's avatar blendimc
I would like to create a pretty extensive extension that would need to run on every single control panel page. Is there a hook for that or some better way to accomplish this function?
Focus Lab Dev Team's avatar
Focus Lab Dev Team
14 years ago
Focus Lab Dev Team's avatar Focus Lab Dev Team
At what point in the page load would you need to execute code?
Off the top of my head I’d suggest looking at the sessions_end hook.
blendimc's avatar
blendimc
14 years ago
I forgot to mention that. Its a permission type extension, so if the page was not supposed to be displayed, I would want to prevent the page from displaying and redirect to another screen.
Focus Lab Dev Team
14 years ago
The sessions_end hook is executed on every single page load (front and back end) so you can execute whatever code you want there processing your permissions code.
blendimc's avatar
blendimc
14 years ago
Focus Lab Dev Team
14 years ago
If you only need to use this code in the CP you should also consider adding a wrapping conditional around your required code which checks if the page load is a CP page.
public function sessions_end()
   if (REQ == 'CP')
       // your code here
