Cp lockout when changing password
Developer Preview
NicoDG's avatar
NicoDG
14 years ago
NicoDG's avatar NicoDG
After updating your member password, access is refused using the new password.
When i remove the salt value from the db members table and try with the same details, it works and a new salt is generated
Greg Ferrell's avatar
Greg Ferrell
14 years ago
Greg Ferrell's avatar Greg Ferrell
I am having this same issue. Password changing due to the salt seems borked.
Greg Aker's avatar
Greg Aker
14 years ago
Greg Aker's avatar Greg Aker
We caught this bug after we did the build. You can delete the salt for your member in exp_members, and it should then work.
