Using entry single variable names when Plugin tag inside
Claudio Cologni's avatar
Claudio Cologni
14 years ago
Claudio Cologni's avatar Claudio Cologni
Im working on a plugin who provides informations to a second plugin. Both plugins returns variables from a external database.
The problem are the variables with the same name… when they return. I need values from the first plugin, and also from the second one when I’m on it.
The variable name are {secao_nome}, {grupo_nome}, {departamento_nome}.
Below is the situation
pre>{exp:produtos:get id="{segment_2}" parse="inward"} {secao_nome} {grupo_nome} {departamento_nome}</p> <p>{exp:secoes:lista grupo="{grupo_nome}" departamento="{departamento_nome}" }</p> <pre><code><li><a href="http://{path=">{secao_nome}</a></li>
{/exp:secoes:lista} {/exp:produtos:get}
Similar question http://ellislab.com/forums/viewthread/55870/
Moved to Development and Programming by Moderator
Sue Crocker's avatar
14 years ago
Hi, Claudio.
Programming questions are more on topic in the Development forum. Moving there for additional community support.
Claudio Cologni
14 years ago
Anyone can help with this?
