Unable to get action ID using fetch_action_id when not logged in
OutofControl's avatar
OutofControl
14 years ago
OutofControl's avatar OutofControl
Using EE 1.7.1 and writing a module. I have the module working great when logged in. However, when I am not logged in, I can’t get the action ID.
Using:
$FNS->fetch_action_id( $class_name, $method_name );
Focus Lab Dev Team's avatar
Focus Lab Dev Team
14 years ago
Focus Lab Dev Team's avatar Focus Lab Dev Team
James,
What does the code look like surrounding the code you provided? I whipped up a test plugin that successfully uses the code you provided for both logged in users and site guests. It was also in 1.7.1. (I just tested against an existing action in the database).
Thanks Erik
Focus Lab Dev Team
14 years ago
Here’s the code I used to test:
<?php
$plugin_info       = array(
    'pi_name'        => 'For James',
    'pi_version'     => '1',
    'pi_author'      => 'Erik Reagan',
    'pi_author_url'  => '',
    'pi_description' => 'Testing something for James',
    'pi_usage'       => ''
class For_james
    public $return_data  = "";
    public function For_james()
        global $FNS;
        $this->return_data = $FNS->fetch_action_id('Member','update_un_pw');
I dumped the user session data to verify that I tested with logged in users and guests.
OutofControl
14 years ago
Hi Erik,
Thanks for the reply! Knowing it should work, I rechecked my module only to find I was jumping ship in the constructor if no Member_ID was present. I modified the code accordingly and all works fine now.
Thanks for the help.
  • James
Focus Lab Dev Team
14 years ago
Excellent. Glad you got it sorted
