Hi transparentb, Take a look at this thread. Does that help?
I don’t think so. I’d like members to be able to upload their own, but start with a default one.
Thank you!
Each Forum I’m installing I ask myself, why does EEs Discussion Module not have a «if no_avatar» or «if avatar … if:else …» to display something if the member does not have a Avatar … is there really no chance to do so!?
@Natetronn: Discussion-Module breaks if you use if:else in the «if avatar»-conditional … there also is no «if no_avatar» or no possibility like «if avatar == ”» or «if avatar == false» … :-/
hmm, {avatar_url} has a default value if none is set by the user right? So you might be able to do a {if avatar_url == 'http://blablabla/default.png'} .. or {if '{avatar_url}’ == ‘http://blablabla/default.png’}
And “advanced conditionals” rarely work in the forum templates.
I’d use gravatar if I were you though. Easier.
Hi Stefan,
The avatar_url tag is available if you use the Member Custom Profile Data tag.
@transparentb,
I think the only way to do this would be to create a simple extension perhaps using the member_member_register hook. Would you like me to move this thread to the Development & Programming Forum for you?
Cheers
Greg
Hi Stefan, The avatar_url tag is available if you use the Member Custom Profile Data tag. @transparentb, I think the only way to do this would be to create a simple extension perhaps using the member_member_register hook. Would you like me to move this thread to the Development & Programming Forum for you? Cheers Greg
Sounds good to me. Thanks.
