Creating Module Links - Disallowed Characters
Codehack's avatar
Codehack
15 years ago
Codehack's avatar Codehack
I’m trying to create a module that uses Ajax on the backend. Since this has a Control Panel backend, I need to do ajax calls to the module. I’ve tried unsuccessfully to generate calls to the module using EE links and constants, but I keep running against roadblocks. The generated links have semicolons, which in turn generate ‘Disallowed Character’ errors.
Ex: In my javascript code
var link = <?= BASE. AMP .'C=addons_modules'.AMP.'M=show_module_cp'.AMP.'module=featured'.AMP.'method=find_franchise'; ?>
No matter how I code it, even when I specifically use the ‘&’ character, EE strips it out and replaces it with &
Suggestions?
Victor Michnowicz's avatar
Victor Michnowicz
about 15 years ago
Victor Michnowicz's avatar Victor Michnowicz
This prolly is not best way to do this, but I added another action in the exp_actions table. In the upd.my_module.php file I have the following:
$data = array(
    'module_name' => 'My_module' ,
    'module_version' => $this->version,
    'has_cp_backend' => 'y',
    'has_publish_fields' => 'n'
$this->EE->db->insert('modules', $data);
// For exp_actions
$data = array('class' => 'My_module', 'method' => 'i_love_ajax');
$this->EE->db->insert('actions', $data);
This allows you to use then use some JS like this:
$.post(BASE_URL, {
        ACT: $(new_option).find('input[name="ee_polls_ajax_add_option_action_id"]').val(), // Action ID
        my_module: 'is cool',
        i_am: 'also cool'
    }, function(data) {
        console.log〈data〉;
}, 'json');
(“BASE_URL” is a JS variable with the base URL of the site)
However, by doing this, you let anyone access this i_love_ajax method. Inside this method you must make sure that the current user is allowed to access. You can do this by checking the current member group ID.
this->session->userdata('group_id')
If the group ID is 1, then you got a super admin and they can access it for sure. If its not 1 you should check the module_member_groups table.
There is probably a way better way of doing this… but its the only thing I could come up with.
Codehack's avatar
Codehack
about 15 years ago
Thanks, it seems like after lots of searching and the discussion on this thread:
http://ellislab.com/forums/viewthread/175788/
the actions table method is the generally accepted way to do it.
Parse19's avatar
Parse19
about 15 years ago
Parse19's avatar Parse19
I’m not sure if this applies or not, but here is an overview of making AJAX calls within the CP. You can solve your original problem with using some JS variables EE generates.
http://forrst.com/posts/ExpressionEngine_Control_Panel_AJAX-OZJ
Victor Michnowicz
about 15 years ago
^ Sweet, thanks dude.
