As far as WYSIWYG editors go, CK Editor is awesome, but the default UI icons are chunky and ugly.
I found a thread that offers a rebuild on the default icon set, based on Fugue icons by http://p.yusukekamiyamane.com:
http://cksource.com/forums/viewtopic.php?p=42302#p42302
These are way, way, way sexier. A must have for CK Editor.
See attached screenshot for an example, and icons.png for the replacement icons file.
Note: the attached icons.png replaces icons.png in /ckeditor/skins/kama/ if you are using kama as the default skin. Should be a simple drag and drop, but make a backup!
Note #2: for some reason the icons.png posted in that thread didn’t work for me (something with PNG-8 vs PNG-24), so I rebuilt it. There’s about 4 icons missing from this sprite at the bottom that deal with editors using right-to-left editing. If that’s you, you can replace those icons yourself by using the original icons.png as the base. I have no use for these icons, so I didn’t add them…
Note #3: The screenshot shows CK Editor running via DM EECK Editor in a Safecracker form. The world is one at last, people.
