Where is author ID stored?
Environ-IT's avatar
Environ-IT
15 years ago
Environ-IT's avatar Environ-IT
I want to query the exp_channel_data table for entries created by a particular author (actually the currently logged in user). Where is the link between the records in this table and the user_id of the entry’s author?
Andrew
Focus Lab Dev Team's avatar
Focus Lab Dev Team
15 years ago
Focus Lab Dev Team's avatar Focus Lab Dev Team
Hey Andrew
The author ID is stored in the exp_channel_titles table under the column ‘author_id’.
Focus Lab Dev Team
15 years ago
Have you considered just using the exp:channel:entries tag pair with the author_id parameter in use? I don’t know if that’s exactly what you need but though I’d point you in that direction just in case.
http://ellislab.com/expressionengine/user-guide/modules/channel/parameters.html#par_author_id
lebisol's avatar
lebisol
15 years ago
lebisol's avatar lebisol
exp_channel_titles and you can relate the tables through entry_id. Also, consider this.
Environ-IT's avatar
Environ-IT
15 years ago
Great thanks for the pointer to the correct table, and yes I would normally just use the exp:channel:entries tags, but in this case I’m writing a query joining custom tables, so it wouldn’t apply.
Thanks again
Andrew
