Plugin development: Working with channel (and other) dates... Tips? Not sure how to do this...
mhulse's avatar
mhulse
15 years ago
mhulse's avatar mhulse
Hi!
Currently, I am doing something like this:
{exp:myplug}{entry_date}{/exp:myplug}
I then manipulate entry_date and return a value. Pretty basic.
What I would like to do:
{exp:myplug timestamp="%Y %m %d"}{date}, {time}, {other}{/exp:myplug}
…and:
{exp:myplug timestamp="entry_date"}{date}, {time}, {other}{/exp:myplug}
…and/or:
{exp:myplug timestamp="{some_date_variable}"}{date}, {time}, {other}{/exp:myplug}
Where I then return values to the tags inside the plugin tag pair for more flexibility.
Basically I want to give the users the most flexibility for when it comes to passing my plugin a valid timestamp (not necessarily from the channel entries tag) and then I want to make it easy for them to use the return values in their template.
I just don’t know how to handle the “timestamp” parameters like I show above… Is the above example even a good idea?
Any tips would be spectacular!
I am currently trying to dissect as many date/time plugs as I can… Could you point me towards a plugin, or docs, that do something similar to my examples above?
Alternatively, is there a better/standardized approach to what I am trying to do?
Thanks! Micky
mhulse's avatar
mhulse
15 years ago
Ack! Not sure why I did not test this… Not sure why I did not think this would work… But, this works:
{exp:myplug field="{entry_date}"}...{/exp:myplug}
Must be my brain is in a different templating language right now… Lol.
Cheers, Micky
mhulse's avatar
mhulse
15 years ago
Ugh, when I use php’s date() function on {entry_date}, the date/time value is several hours off… I tried using some of the EE built-in localize methods, but it seems like they all want to localize to the current logged-in user, and not the TZ of the EE installation.
I am guessing that I don’t know enough about how dates work in EE to figure this one out… I am sure I could find a PHP solution to get the TZ corrected, but there has to be an easy way to get EE to help me out on this one?
Any tips?
Thanks! Micky
mhulse's avatar
mhulse
15 years ago
When I replace PHP’s date() with $this->EE->localize->decode_date() I get the localized time…
I guess I am confused about how decode_date() works. When I log out of EE, the date value printed on the page stays the same… I assumed that the localization of decode_date() was based on the current logged-in user?
decode_date calls set_localized_time() which says this:
“Converts GMT time to the localized values of the current logged-in user”
So, why does the date stay the same when I log out? Can I use this to localize the date to the EE installation and not the “current logged-in user”?
Anyone out there? :D
Thanks! Micky
mhulse's avatar
mhulse
15 years ago
After having thought about it a little more, I think my problem is with my understanding of how localization is supposed to work.
After a little bit of sleuthing, I discovered that my installation’s localization server timezone was not set to the timezone of the physical location of the server… I had it set to -8 pacific time (my timezone), when it should have been -5 eastern (server timezone)!
Next, I checked my login timezone, and that was set to -8 pacific. This is how it should be… No problems here.
When I change my login TZ to another timezone, the date output generated by $this->EE->localize->decode_date() changes with the change in zone.
Not sure if I am making any sense… Part of me feels like date() is much cleaner to write than $this->EE->localize->decode_date(), but the latter appears to be giving me the results I want vs. the former.
For example:
$t = date('H:i', $this->timestamp);
$t = $this->EE->localize->decode_date('%H:%i', $this->timestamp);
I use the decode_date method in several locations (in place of date()) and it just seems like I might be going overboard with its usage… Then again, it is just a simple method call.
Anyway, I will post a link to my plugin as soon as I have it finished just in case someone wants to give me a little feedback.
Cheers, Micky
mhulse's avatar
mhulse
15 years ago
Not that anyone is listening… But what the heck! Here’s the plugin.
I call it APStylee… Brief description:
This ExpressionEngine v2 plugin converts a timestamp into an Associated Press style formatted date and time.
I am open to feedback.
Cheers! Micky
