Plugin within a Plugin
chrcollins's avatar
chrcollins
15 years ago
chrcollins's avatar chrcollins
I wrote a plugin I want to wrap around the imgsizer plugin. I debugged my plugin and it works ok on its own but it doesn’t work when I put the imasizer plugin inside the tag…
{exp:dirdump dir='./nest/proj/images/facility'}
  {exp:imgsizer:size src="{file}" width="200"}
      {sized}
  {/exp:imgsizer:size}
{/exp:dirdump}
I suspect that when the $this->EE->TMPL->fetch_param() function in the plugin is confused by the imgsizer tag and does not see the {file} param hiding within. Is there a post or wiki that discusses this issue and how to deal with it? Do I have to parse the imgsizer tag on my ownI am going to look at some of the other modules that can do this and try and reverse engineer it.
E.E. version 2.1.1 Build: 20101020
Laisvunas's avatar
Laisvunas
15 years ago
Laisvunas's avatar Laisvunas
It seems that exp:dirdump tag should have
parse="inward"
parameter.
chrcollins's avatar
chrcollins
15 years ago
Thanks for the reply ….
I tried adding it to my dirdump tag and it did not help.
box-head's avatar
box-head
15 years ago
box-head's avatar box-head
Hi chrcollins,
I’m needing to do somehting similar (plugin within a plguin). Did you manage to get any further with this?
Thanks.
