I have a channel set up that has a related entries field, and I want to be able to display all entries in this channel that share the same related entry. So, basically I’m wanting to use the related entry field as a way of categorizing/sorting entries, in addition to it’s standard function. I should be able to do this using the query mod, but I’m having a little trouble with the query itself.
I have a template set up that will use the following query:
{exp:query sql="
SELECT
t.title,
t.url_title AS permalink,
t.entry_id AS entry_id,
t.author_id AS author_id,
d.field_id_1 AS layout
FROM
exp_channel_data AS d,
exp_channel_titles AS t
WHERE t.channel_id = '2'
AND d.field_id_21 = '{segment_3}'
AND t.entry_id = d.entry_id"
}field_id_21 is my related entries field, and segment_3 is where the entry id of the related entry I want to sort by is stored. This query calls and displays all the wanted data correctly, but it calls ALL the entries in the channel, not just the ones where field_id_21 = segment_3. My knowledge of queries like this is pretty basic, so I’m probably overlooking something simple. Can anyone help me out?
The relationship field doesn’t actually store the weblog entry id of the related entry. It actually stores the relationship id from the exp_relationships table. I think in your case, you will want to do a join on the relationships table and a where on the rel_child_id = {segment_3}
Thanks for your reply, Tom. I took a look at my EE database again, and I get how the exp_relationships table works in now, but now it seems to me I need to join three tables: exp_channel_data & exp_channel_titles, and exp_channel_data & exp_relationships–and I’m not sure how to go about that. I came up with the following, but it’s extremely convoluted and doesn’t work:
{exp:query sql="
SELECT
t.title,
FROM
exp_channel_titles AS t,
exp_relationships AS r
AND t.entry_id = d.entry_id,
AND d.field_id_21 = r.rel_id,
AND r.rel_child_id = '{segment_3}';"
}I’m pretty new to SQL queries, so any pointers you can give me would be MUCH appreciated. What am I doing wrong? Is there a better way to join this data?
I would look to actually do an SQL JOIN in this case.
(simple example) SELECT your_fields FROM exp_channel_data JOIN exp_relationships ON exp_channel_data.entry_id = exp_relationships.rel_child_id WHERE field = something
These links may be of help for you http://www.wellho.net/mouth/158_MySQL-LEFT-JOIN-and-RIGHT-JOIN-INNER-JOIN-and-OUTER-JOIN.html http://dev.mysql.com/doc/refman/5.1/en/join.html
That example makes perfect sense to me, but it’s only joining two tables. Where I get hung up is when I need to join a third table, because I need to pull data from the exp_channel_titles AND exp_channel_data tables based on a value in the exp_relationships table. Can I do multiple joins in one query?
Something like this:
SELECT exp_channel_data.my_fields, exp_channel_titles.my_fields
FROM exp_channel_data, exp_channel_titles
JOIN exp_channel_titles ON exp_channel_data.entry_id = exp_channel_titles.entry_id
AND exp_relationships ON exp_channel_data.entry_id = exp_relationships.rel_child_id
WHERE field = somethingIn the case of a JOIN instead of using an AND like you would in a WHERE clause you use another JOIN statement.
SELECT exp_channel_data.my_fields, exp_channel_titles.my_fields FROM exp_channel_data, exp_channel_titles JOIN exp_channel_titles ON exp_channel_data.entry_id = exp_channel_titles.entry_id AND exp_relationships ON exp_channel_data.entry_id = exp_relationships.rel_child_id WHERE field = something
would be
WHERE field = somethingThanks, Tom! That makes a lot more sense. I retried my query as follows, using two JOINs:
SELECT t.title, t.url_title AS permalink, t.entry_id AS entry_id, t.author_id AS author_id, d.field_id_1 AS layout
FROM exp_channel_data AS d, exp_channel_titles AS t
JOIN exp_channel_titles ON exp_channel_data.entry_id = exp_channel_titles.entry_id JOIN exp_relationships ON exp_channel_data.entry_id = exp_relationships.rel_parent_id
WHERE t.channel_id = ‘2’ AND exp_relationships.rel_child_id = ‘{segment_3}’
But now I get a 1054 error that says “Unknown column ‘exp_channel_data.entry_id’ in ‘on clause’”, and I’m wondering if it’s because I’m calling the same column (exp_channel_data.entry_id) in two different JOINs?
