Error with echo/var_dump in extension
fusepilot's avatar
fusepilot
15 years ago
fusepilot's avatar fusepilot
While developing an extension, I tried to echo/var_dump a variable. It outputs to the very top of the page as expected. But, it throws this error right underneath it:
A PHP Error was encountered
Severity: Warning
Message: Cannot modify header information - headers already sent by (output started at /Applications/MAMP/htdocs/site/system/expressionengine/extensions/ext.my_extension.php:35)
Filename: libraries/Functions.php
Line Number: 739
It also doesn’t send any page headers. However, the rest of the page loads fine.
What’s going on here?
Moved to Development and Programming by Moderator
Greg Aker's avatar
Greg Aker
15 years ago
Greg Aker's avatar Greg Aker
It’s just a byproduct of you outputting something after headers have been sent. your final products won’t be echo’ing from extension methods, so you have nothign to worry about. 😊
