Search module hack (EE 1.6.9)
Mark Croxton's avatar
Mark Croxton
15 years ago
Mark Croxton's avatar Mark Croxton
If you need the search module to return entries that belong to ALL of the selected categories in the advanced search form (rather than the default which selects entries in ANY of the selected categories), change this at around line 952:
        /**  Limit query to a specific category
        if (isset($_POST['cat_id']) AND is_array($_POST['cat_id']))
            $temp = '';
            foreach ($_POST['cat_id'] as $val)
                if ($val != 'all' AND $val != '')
                    $temp .= " exp_categories.cat_id = '".$DB->escape_str($val)."' OR";
            if ($temp != '')
                $temp = substr($temp, 0, -2);
                $sql .= ' AND ('.$temp.') ';
to:
        /**  Categories
            if ($_POST['cat_id'][0] != 'all' && $_POST['cat_id'][0] != '')
                // Find entries that belong to ALL selected categories
                $cat_sql = "SELECT
                            DISTINCT(exp_weblog_titles.entry_id)
                            FROM exp_weblog_titles
                            LEFT JOIN exp_weblogs ON exp_weblog_titles.weblog_id = exp_weblogs.weblog_id
                            LEFT JOIN exp_category_posts ON exp_weblog_titles.entry_id = exp_category_posts.entry_id
                            WHERE exp_weblogs.site_id = '".$DB->escape_str($PREFS->ini('site_id'))."'";
                // make safe
                foreach($_POST['cat_id'] as &$val)
                    $DB->escape_str($val);
                $selected_categories = "'".implode("','", $_POST['cat_id'])."'";
                $cat_sql .= "AND exp_category_posts.cat_id IN ({$selected_categories})
                         GROUP BY exp_category_posts.entry_id
                         HAVING (COUNT(exp_category_posts.entry_id) = ".count($_POST['cat_id']).") ";
                $query = $DB->query($cat_sql);
                if ($query->num_rows == 0)
                    return FALSE;
                else
                    // add where condition to main query
                    $sql .= "AND exp_weblog_titles.entry_id IN(";
                    foreach ($query->result as $row)
                        $sql .= "'".$DB->escape_str($row['entry_id'])."', ";
                    $sql = substr($sql, 0, -2).")";
