Serverside events for saving channel entries in the admin area
TonicTheAgency's avatar
TonicTheAgency
15 years ago
TonicTheAgency's avatar TonicTheAgency
Hi there, Iam new to expression engine and would like to know is it possible to write custom code for the channel entries screen in the admin area?
Specifically what i like to do is: 1. When a new channel record is saved, i would like to do a uniqueness check on a particular field. If there is already an existing value, alert the user that the new channel entry cannot be added 2. Similarly when a new channel record is saved, i would like to run a custom sql query to inject a record into another table eg say iam saving a channel record - a user id and a product id, i would like to update the total spend field for that user on the user table.
Appreciate if anyone can guide me the most appropriate way to do the above..
thanks
al
Moved to Development and Programming by Moderator
Sue Crocker's avatar
15 years ago
Welcome to the ExpressionEngine forums, al.
I’m going to move this thread to the Development forum. What you’re describing sounds like what an extension would do.
