Channel Entries API enforcing required custom fields from irrelevant channels
ender's avatar
ender
15 years ago
ender's avatar ender
I’m trying to use the Channel Entries API to programmatically create some entries and seem to have run into a bug.
I’m attempting to insert entries into channel #5 (Counties). It has one custom field (#17).
There are two custom fields in the EE installation that are required: “Summary” from channel #4 and “City” from channel #6.
My code looks like this:
$data = array(
    'title' => 'some title',
    'channel_id' => 5, // necessary because of other bug that is marked fixed for next release
    'entry_date' => '2010-09-10 01:40 PM',
    'field_ft_17' => 'xhtml',
    'field_id_17' => 'whatever'
if ($this->EE->api_channel_entries->submit_new_entry(5, $data) === FALSE)
    show_error('An Error Occurred Creating the Entry');
A print_r of the errors set by the API looks like this:
Array (
    [Summary] => The following field is required:
    [City] => The following field is required:
The culprit appears to be the following code in Api_channel_entries.php, function _check_for_data_errors, roughly line 1125:
// Required and custom fields
$this->EE->db->select('field_id, field_label, field_type, field_required');
$query = $this->EE->db->get('channel_fields');
Seems like the solution would be to filter that database select on the current channel’s assigned field group.
Moved to Development and Programming by Moderator
Sue Crocker's avatar
15 years ago
Hi, Ty. This sort of question is more appropriate for the Developer forum. Moving there for additional community support.
Rob Sanchez's avatar
Rob Sanchez
15 years ago
Rob Sanchez's avatar Rob Sanchez
I noticed this, too, the other day. Curious that the field_model wasn’t used here.
