Hide channels from publish tab
magnusland's avatar
magnusland
15 years ago
magnusland's avatar magnusland
Is there a way to hide channels from the publish tab (but not the possibility to edit entries belonging to that channel) without any extensions? There was a perfect solution for this in EE1, but can’t seem to find a way to do it in EE2.
hd 's avatar
hd
15 years ago
hd 's avatar hd
You can edit a specific member group’s permissions under “Channel Assignment”. Unfortunately this puts editing and publishing together, so there is not yet a native way to do what you are asking.
It might be helpful for someone to port that add-on to EE2, but it isn’t exactly secure. It’s purely for aesthetics and simplification for clients.
What exactly do you need this for?
magnusland's avatar
magnusland
15 years ago
I need it for exactly what you said; making EE as simple and bulletproof for the client as possible. The fewer possibilities they have to mess things up the better 😊
And I agree; if someone could port the plugin to EE2 it would be extremely helpful!
hd 's avatar
hd
15 years ago
hd 's avatar hd
If there is content that the client doesn’t need to edit, but may need to be edited by an admin (or an IT person working for the client) I’ll have it in it’s own channel that only admins can see, or use a snippet (if it’s global content). Or if the site uses the category structure, I’ll have a special category group for pages of the site that are outside the scope of the navigation, and disallow access to that category group for new channel entries.
magnusland's avatar
magnusland
15 years ago
I want the clients to be able to edit entries in a channel, but not to create new ones. That plugin for EE1 works exactly and perfectly like that. Mmm, yummy, wish there was one for EE2!
magnusland's avatar
magnusland
15 years ago
Would anyone be able to and interested in porting this to EE2?
MediaGirl Inc.'s avatar
MediaGirl Inc.
15 years ago
MediaGirl Inc.'s avatar MediaGirl Inc.
I’m needing this as well. Loved this extension in v1.6.x!
Heiko's avatar
Heiko
15 years ago
Heiko's avatar Heiko
It seems there is a version for EE2 now, but I can’t get it to work properly.
