Custom member field types
Electric Putty's avatar
Electric Putty
15 years ago
Electric Putty's avatar Electric Putty
Hello,
We need to add some custom member fields which are select lists. The tricky bit is the options within them need to be populated from a database table.
Does anyone know if there is a hook available to add a new custom member field type?
Many thanks,
Malcolm
Adrian Macneil (Crescendo)'s avatar
15 years ago
Adrian Macneil (Crescendo)'s avatar Adrian Macneil (Crescendo)
Not that I know of, but I was thinking of developing a module in the near future to allow members to have custom fields using any standard custom field type, if there isn’t any existing way to do it.
Did you find a solution?
Electric Putty
15 years ago
Hi Adrian,
No, I couldn’t find any existing solution to this and don’t have the time to write something from scratch so have had to find another way of tagging my members.
If you do make any progress with an add-on I’d be very interested to hear about it.
Thanks and best wishes,
Malcolm
Apple Soda's avatar
Apple Soda
15 years ago
Apple Soda's avatar Apple Soda
I know this isn’t exactly what you’re after, but I was looking to see what options are available myself and came across this: http://expressionengine.com/wiki/Enable_radio_buttons_and_checkboxes_for_custom_member_profile_fields/
Hopefully it helps in some way!
StudioKong's avatar
StudioKong
15 years ago
StudioKong's avatar StudioKong
I am stuck here too while building a proof of concept: I need to link members to channel entries (a companies channel). It would be great to have a custom member field (drop down list) that is populated by the channel.
I know there are member field types to link channel entries to members (eg. Member List Custom Field - http://devot-ee.com/add-ons/member-list-custom-field/) or you could use Solspace’s User module to assign multiple authors/members to a channel entry, but it would be more logical to link the member to its company by using a custom member field.
Any idea on how to do this? Or should I consider another approach?
Koen
jonnyquist's avatar
jonnyquist
14 years ago
jonnyquist's avatar jonnyquist
Heh, so, uh, ever figure something out, StudioKong?
StudioKong's avatar
StudioKong
14 years ago
Hi Erich,
Check out Zoo Visitor: http://ee-zoo.com/add-ons/visitor. A great add-on that solves a lot of problems and shortcomings you face with default custom member fields.
