Hello,
I am trying to create a new type of fieldtype and need some help from someone who’s done it before.
I would like to create a select (dropdown) fieldtype. Easy enough, until the client wants to add a new item to the select list. Then they have to go to the Admin tab, choose custom fields, and add a new item. Again, not so hard, except that I don’t give my clients access to the Admin tab. This is common enough of an issue that I’m having a hard time believing this feature doesn’t already exist.
So what I need is a text input on the Publish page and a checkbox that says “create new” or something like that. If that box is checked, it will look to the text input and ignore the select element. It takes the text input’s value, saves it to the list for next time, and uses that value on the resulting page.
I’ve been tinkering with it for some time, but I’m just not a strong enough PHP or CI developer to sort it out by myself. Anyone got any insight? I’d sure appreciate it.
Marcus
I need the same and try to make it. I suppose the architecture will be as follows: 1. create custom field type (dropdown + input) for publish form 2. create extension and use “entry_submission_ready hook” for example 3. extension will get posted data and compare values of our field and field_list_items and if no match - insert the new one in field_list_items
Here we come! Needs testing. I’ve struggling with save revisions (I use it) - there’s no hooks for it, so I’ve made a little trick with save revision button…
here the link to addon
well, welcome feedback…
Tried that and it got rid of the 2nd of the three notifications, but the other two still exist.
I’m trying to find where the revision_submit name attribute actually gets applied somewhere. Looking at the JS in your ft.cstslct.php file, I’m not seeing any element on the page with an ID of revision_button, so I’m not sure the revision_submit name is ever getting applied somewhere.
Element with ID of revision_button appears when you Enable Entry Versioning (CP Home-Administration-Channel Management-Channel Preferences) to save Revision of an Entry and get back to edit form (I always use revisions).
But this JS don’t affect to this error, even if there is no revision_button - It just ignore it.
Usually such a type of PHP error happens when I forget quotes, I think… I’ll try to catch this error
PS third error will disapear when get rid of first
Hey all, as per our Community Guidelines, we don’t allow distribution of third-party add-ons or related support on our forums. There are some great recommendations in that thread for where to host addons and offer support.
We do allow you to receive support for building those add-ons in these forums, though.
Thank you for understanding!
Hi, Adrian,
You can read our blog post about this decision.
And the add-on was actually attached in the post, before I removed it, which is why I popped in here.
A link to Devot-ee would be perfect.
Thank you!
