Help with .htaccess for specific purpose
dimitar.mihaylov's avatar
dimitar.mihaylov
15 years ago
dimitar.mihaylov's avatar dimitar.mihaylov
Hey everybody,
I need some help with setting up a .htaccess file for my EE2 installation. I have a web folder, where my index.php file takes place:
/folder/.htaccess
/folder/index.php
What I have there as well is another folder with its own index.php and .htaccess file:
/folder/cifolder/.htaccess
/folder/cifolder/index.php
So, “folder” is the EE2 one, while “cifolder” is referring to CodeIgniter website. The end goal is:
http://website.com/ - to open EE website http://website.com/cifolder/ - to open CI website
This is what I currently have in /folder/.htaccess:
RewriteEngine On
RewriteBase /
RewriteRule ^(.*)$ index.php/$1 [L]
It does the magic, if I open http://website.com/cifolder/. However, if I try http://website.com/cifolder/something-else, I get 404 from EE. What else do I need to put in my .htaccess file?
Thanks! 😊
hd 's avatar
hd
15 years ago
hd 's avatar hd
I’m no .htaccess expert but I’d try:
RewriteEngine On
RewriteBase /
RewriteCond $1 !^(index\.php|cifolder)
…so that your cifolder links do not get handled by EE.
And then inside the “cifolder” put another .htaccess to handle removing that nested index.php using code like what you’ve posted.
dimitar.mihaylov
15 years ago
Thanks, HD. Unfortunately, this combination doesn’t work, too. I presume that something else is needed in this line in order to “tell” to not check anything after /cifolder/, not just the folder itself:
hd 's avatar
hd
15 years ago
hd 's avatar hd
Have you tried also removing the file & dir checking…
You may have to explicitly list image/css/robots.txt/etc inside that line along with cifolder.
dimitar.mihaylov
15 years ago
Yes, I tried that as well, no luck indeed. There is nothing else in this folder, but .htaccess, index.php and cifolder, so what I need to exclude is the latter only.
Chuck Liddell's avatar
Chuck Liddell
15 years ago
Chuck Liddell's avatar Chuck Liddell
Here is what I use on my site:
RewriteEngine on
RewriteCond $1 !^(index\.php|admin\.php|app1\.php|app2\.php|assets|lib|robots\.txt)
Everything is passed to index.php except the things I list explicitly.
admin.php, app1.php, app2.php are all loaders (admin is EE backend, app1 and app2 are CodeIgniter apps).
I keep all my images, css, javascript in the ‘assets’ folder, so calls to one of these look like this:
Hope this helps.
dimitar.mihaylov
15 years ago
Okay, figured it out. Following line was taking place in /cifolder/.htaccess:
RewriteBase /
Works now. Thanks for help, guys! 😊
