can't load a view from a plugin
ender's avatar
ender
15 years ago
ender's avatar ender
this old thread sums it up pretty well: http://ellislab.com/forums/viewthread/138204/
I looked around for any updates or evidence this problem got fixed and didn’t find anything. Should this be viewed as a bug and added to the tracker or is it working as intended?
ender's avatar
ender
15 years ago
as an update, it doesn’t work in the mod.whatever.php files, only the mcp.whatever.php files. So basically can’t use views in the front end except via fieldtypes.
Darren Miller's avatar
Darren Miller
15 years ago
Darren Miller's avatar Darren Miller
You can - and I do so regularly - but you have to wrench things into shape a bit.
There are pros and cons to the method, as discussed here: http://ellislab.com/forums/viewthread/160486/#772269
ender's avatar
ender
15 years ago
edit: err, nevermind. was thinking of the wrong thread. thanks for the link, and that’s essentially what I ended up doing as well.
