Seesaw 0.4.9
Marc Miller's avatar
Marc Miller
15 years ago
Marc Miller's avatar Marc Miller
Hmm - kind of a pain to start a new thread and have to manually notify the creator rather than continuing a thread from the old system and sending auto-notifications. /end gripe.
Two things. 1) Upgradeing from 0.4.8 to 0.4.9 gives me PHP errors:
Notice: Undefined index: custom_fields in /home/site/public_html/system/extensions/ext.seesaw.php on line 853
Warning: array_key_exists() expects parameter 2 to be array, null given in /home/site/public_html/system/extensions/ext.seesaw.php on line 853
Some google searching makes me think the error is caused by PHP 5.3. Does array_merge not work the same in 5.3? If I comment out line 829
$settings[$channel_id][‘custom_fields’] = array_merge($custom_fields , $gypsy_fields);
and put it the 0.4.8 version:
$settings[$channel_id][‘custom_fields’] = $custom_fields;
I don’t see the errors, but obviously, I’m also not getting the full benefits of .9 either.
2) I made some modifications to get this feature request in and working with an MSM site.
  1. Find around line 748:
// start off with the default edit view
        $settings = array(
            'channel_0' => array(
                'title' => $LANG->line('default_view'),
                'core_fields' => $this->available_core_fields,
                'custom_fields' => array()
Replace:
        $settings = array(
                'site' => $LANG->line('default_view'),
  1. Find around line 776
// query for channels
        $channels_query = $DB->query('SELECT weblog_id, blog_title, field_group
                             FROM ' . $this->db_prefix . '_weblogs');
Replace:
        $channels_query = $DB->query('SELECT s.site_label AS site_label, w.weblog_id AS weblog_id, w.blog_title AS blog_title, w.field_group AS field_group
                             FROM ' . $this->db_prefix . '_weblogs w INNER JOIN '. $this->db_prefix .'_sites s ON s.site_id = w.site_id');
  1. Find around line 781
foreach($channels_query->result as $channel) {
                $channel_id = 'channel_' . $channel['weblog_id'];
                $settings[$channel_id] = array(
                    'title' => $channel['blog_title'],
Replace
                    'site' => $channel['site_label'],
  1. Find around line 305
$DSP->body .= $DSP->qdiv('defaultBold', $channel_settings['title']);
Replace
$DSP->body .= $DSP->qdiv('defaultBold', $channel_settings['site'] . ' : ' . $channel_settings['title']);
Technically, this will work whether or not you have the MSM installed, but I guess there’s no reason to do this if you don’t have it.
