Session across MSM
David Dexter's avatar
David Dexter
15 years ago
David Dexter's avatar David Dexter
I’m trying to pass information across MSM with the session_id but there seems to be a strange issue. The primary site always returns the correct session_id however the other sites return a different sid value on every page load. To test I’m running a simple function through an extension test… Below is a copy of the function.
function sid(){
    return $this->EE->session->userdata['session_id'];
Why are the other sites generating a new session_id value on each page load?
Thanks, David
David Dexter
15 years ago
After looking into this a bit more I now realize that I was trying to use this in the wrong fashion. So is there a way to share a key value across multiple sites with EE? I’m trying to create a MSM module and need to be able to pass sessions for both guests and logged in users.
Thanks, David
Pascal Kriete's avatar
Pascal Kriete
15 years ago
Pascal Kriete's avatar Pascal Kriete
Logged in users are simple (as long as they are logged in to all sites) - you always have the same user id and unique id.
For guests you will need some trickery to make it work. Session ids are periodically regenerated, so you can’t rely on those. They’re also not the same across sites (as you’ve seen).
Are these sites on the same domain (different subdomains)? Or are they completely separate?
Are you trying to have persistent data that is in sync across sites or is it a redirect that only needs to pass it for one request?
David Dexter
15 years ago
Figured out a solution with a cookie since all of the sites are subdomains of the main site.
Thanks for your reply!
Best, David
