Extension extending Menu library
mrwoods09's avatar
mrwoods09
15 years ago
mrwoods09's avatar mrwoods09
I need to replace the Help button within the control panel of EE2.0 is it possible to create an extension which edits the Menu library file so I can do this?
mrwoods09's avatar
mrwoods09
15 years ago
Still looking for reply to this, what I need is access to the Menu.php library with the ability to change the generate_menu function
NicoDG's avatar
NicoDG
15 years ago
NicoDG's avatar NicoDG
Hi, i created an addon which lets you customize the control panel menu in whatever way you want, maybe this is something that could be helpful for you? http://devot-ee.com/add-ons/ndg-flexible-admin/
