Template IDE - Introducing Bespinee ALPHA!
luke holder's avatar
luke holder
15 years ago
luke holder's avatar luke holder
Hi all,
Introducing Bespinee, the template code editor. This new extension is the beginning of a fully functional Expression Engine Template IDE that is 100% web based. Built on the bespin embedded API.
ALPHA Screenshot:
ALPHA Download:
http://dl.dropbox.com/u/103062/bespineeALPHA.zip
Place the bespinee folder into system/expressionengine/third_party
Please note this is a EE2 only extension.
HOW TO USE: Simply upload as above and enable the extension, then visit a template edit screen. Click into the template text area and a Bespin icon will appear on the right side of the textarea. Just click the icon and WOWSERS, beautiful code.
Features coming very soon:
  • Expression Engine tag highlighting
  • More advanced HTML and PHP code highlighting, with themes. (think textmate)
  • EE tag insert buttons for common tags and global variables, and even:
  • Third Party tag inserts (hosted tag libraries)
  • External Code revision backups
  • And more, let me know what you would like.
hopefully you will enjoy.
Luke Holder
