how do I get the current logged in user's id?
Jayson Ng's avatar
Jayson Ng
15 years ago
Jayson Ng's avatar Jayson Ng
is there a built in function (I need to incorporate it in my module) to grab the currently logged in user’s id?
thanks,
Jayson
patrick-vibes's avatar
patrick-vibes
15 years ago
patrick-vibes's avatar patrick-vibes
{member_id}
http://expressionengine.com/docs/templates/globals/single_variables.html#var_member_id
Max Lazar's avatar
Max Lazar
15 years ago
Max Lazar's avatar Max Lazar
$SESS->userdata('member_id')
Jayson Ng's avatar
Jayson Ng
15 years ago
thank you! It’s the $SESS-> PHP function is what I need.
:D
Jayson Ng's avatar
Jayson Ng
15 years ago
Just a little correction
the correct code is
$this->EE->session->userdata('member_id');
thanks again!
Ingmar's avatar
15 years ago
Ingmar's avatar Ingmar
That would depend on whether you’re using EE 1.6 or 2.0 😊 Thanks for clarifying, though.
Jayson Ng's avatar
Jayson Ng
15 years ago
Ah I see.
EE 2.0 then for it to work ( $this->EE->session->userdata(‘member_id’) )
thanks! 😊
