Creating first plug-in
Vernierst's avatar
Vernierst
15 years ago
Vernierst's avatar Vernierst
I’m adding some outside database queries to a EE template. It works great, but whenever I uncomment the pi_usage section of the $plugin_info array, it seems that the usage code is always run. When I view all the plugins, it just shows the usage information for my plugin, and when I view a template that uses the plugin, I just get the text for the plugin.
Here’s most of the code:
<?php
$plugin_info = array(
    'pi_name' => 'E21 Price Lookup',
    'pi_version' =>'0.75',
    'pi_author' =>'David Lim',
    'pi_description' => 'E21 Product Price Lookup (US Only)',
    'pi_usage' => E21_price::usage()
 * E21_price Class
 * @package        ExpressionEngine
 * @category        Plugin
 * @author        David Lim
 * @copyright        Copyright (c) 2010, David Lim
class E21_price {
    var $return_data = '';
    function E21_price() {
    function usage() {
        ob_start();
The E21 Plugin provides product information from E21.
{exp:e21_price}part_code{/exp:e21_price}
        <?php
        $buffer = ob_get_contests();
        ob_end_clean();
        return buffer;
Any suggestions?
Vernierst's avatar
Vernierst
15 years ago
Never mind, I figured it out. The exampled I pulled from, I don’t know why they used ob_start. All I had to do was return the text I wanted and not use any of the other code.
