Adding own CSS to Control Panel
mark59's avatar
mark59
15 years ago
mark59's avatar mark59
I am trying to add a small amount of CSS to the Control Panel to style a data table within the Module I am writing, and that will appear under the Control Panel.
Tried using the
$DSP->extra_css = “path/to/file.css”;
which is mentioned on the Dev page for the Display class. Does not work (my CSS file is not referenced anywhere in the CP webpage source) - any ideas? Has this ‘undocumented’ feature mentioned on the pages comments been removed? or is it wrong or not available?
I am trying to set this - just where I set the title, crumbs, etc
$DSP->title = $LANG->line('fbtcommerce_module_name');
        $DSP->crumb = $DSP->anchor(BASE.
                                   AMP.'C=modules'.
                                   AMP.'M=fbtcommerce',
                                   $LANG->line('fbtcommerce_module_name'));
        $DSP->crumb .= $DSP->crumb_item($LANG->line('view_basket'));
        $DSP->extra_css = "/css/ecommercecp.css";
mark59's avatar
mark59
15 years ago
Been able to answer my own question
$DSP->extra_css does work - but it needs to be the Full Server Path name of the file and not relative to the website root folder.
Issue Solved.
