FATAL ERROR on enabling extensions in EE2
Brett DeWoody's avatar
Brett DeWoody
15 years ago
Brett DeWoody's avatar Brett DeWoody
I’m trying to create an extension for EE2 and get a fatal error when I try to enable my new extension.
The error is:
Fatal error: Call to a member function insert_string() on a non-object in /path/to/expressionengine/third_party/[extension_name]/ext.[extension_name].php  on line 33
That line corresponds to the activate_extension function:
function activate_extension() {
            global $DB;
            $DB->query($DB->insert_string('exp_extensions',
                                          array(
                                                'extension_id' => '',
                                                'class'        => $this->class_name,
                                                'method'       => "add_libraries",
                                                'hook'         => "publish_form_headers",
                                                'settings'     => "",
                                                'priority'     => 10,
                                                'version'      => $this->version,
                                                'enabled'      => "y"
Line 33 is the $DB->query($DB->insert_string(‘exp_extensions’… line.
Anyone had this happen?
Thanks in advance!
-Brett
Brett DeWoody
15 years ago
Ah, apparently the EE2 version of this is:
$this->EE->db->insert('exp_extensions',
Problem solved. Documentation for EE2 should probably be updated with this though.
Manuel Payano's avatar
Manuel Payano
15 years ago
Manuel Payano's avatar Manuel Payano
The documentation is good 😊 Maybe you where looking at the wrong one. http://expressionengine.com/public_beta/docs/ http://expressionengine.com/public_beta/docs/development/usage/database.html#inserting
Brett DeWoody
15 years ago
I was looking at the Extension Development docs (http://expressionengine.com/public_beta/docs/development/extensions.html) which gave an example as:
//  Activate Extension
    global $DB;
                                  array(
                                        'class'        => "Example_ext",
                                        'method'       => "rewrite_admin_home",
                                        'hook'         => "admin_home_page_start",
                                        'settings'     => "",
                                        'priority'     => 10,
                                        'enabled'      => "y"
// END
