Problem invoking weblog/mod.weblog twice in one plugin
Adam Khan's avatar
Adam Khan
16 years ago
Adam Khan's avatar Adam Khan
For a plugin I’m working on, the weblog module needs to be run twice. But when I run it the second time, it ignores any value in the entry_id parameter. I’m setting that parameter using
$TMPL->tagparams['entry_id']
syntax. Is there perhaps another way to set it?
Update: As often happens, as soon as I post here, I find the solution that had stumped me up to then. Before the second second invocation:
$TMPL->tagparams="";
Rather simple…
