Plugin: Math Plus
Laisvunas's avatar
Laisvunas
16 years ago
Laisvunas's avatar Laisvunas
The attached add-on files may be out of date. Please visit Devot-ee for the latest versions.
This plugin provides support for doing simple mathematical operations in templates.
There is already the plugin Simple Math which has the same purpose.
Math Plus plugin differs from Simple Math only in one feature: it is required to use a tag pair instead of single tag. Tag pair allows for better control of the parse order.
PARAMETERS
1) calculate - Required. Alows you to input a string consisting of numbers, symbols of mathematical operations and round brackets, e.g calculate = “(10 + 5) / 3”. Examples of symbols of supported mathematical operations are: + (addition), - (subtraction), * (multiplication), / (division), % (division remainder), ++ (increment), – (decrement).
2) invalid_input - Optional. Accepts two values: “alert” and “silence”. Default value is “silence”. If the value is “alert”, then in cases when the plugin has some problem with parameters, PHP alert is being shown; if the value is “silence”, then in cases when the plugin has some problem with parameters, it finishes its work without any alert being shown. Set this parameter to “alert” for development, and to “silence” - for deployment.
USAGE
Use this plugin as folllows:
{exp:math_plus calculate="(10 + 5) / 3"}
{math_plus_result}
{/exp:math_plus}
fjldude's avatar
fjldude
16 years ago
fjldude's avatar fjldude
Thanks for creating Math Plus.
It was just what I needed for doing a calculation and passing the result to a another plugin (See this thread).
Cheers!
Santa Fe's avatar
Santa Fe
15 years ago
Santa Fe's avatar Santa Fe
What version of EE was this plugin written for? I’m using EE 2.0 Public Beta and it doesn’t seem to be working. I just placed the sample code into a template and the page comes up blank.
Laisvunas's avatar
Laisvunas
15 years ago
This plugin is for EE 1.x
