Has anyone else encountered an issue with nGen and file sizes?
We’re running a MSM site and uploads over 3MB or so bomb out when uploading. We are using nGen File Field 1.0.
The error we get is:
“Something happened while uploading (filname) Please try again”
We were on an earlier version before upgrading nGen to 1.0 and got an error, although not as pretty as the one in 1.0:
Warning: getimagesize() [function.getimagesize]: Filename cannot be empty in /home/(directory)/public_html/admin/extensions/fieldtypes/ngen_file_field/ft.ngen_file_field.php on line 10 Warning: Cannot modify header information - headers already sent by (output started at /home/(directory)/public_html/admin/extensions/fieldtypes/ngen_file_field/ft.ngen_file_field.php:10) in /home/(directory)/public_html/admin/core/core.functions.php on line 296
probably running into the apache/php upload limit and/or max execution time.
in your admin (system) folder, create a .htaccess file and in it put:
php_value upload_max_filesize 60M
php_value post_max_size 65M
php_value max_execution_time 800unfortunately all servers are configured a little bit differently so that might or might not work, but hopefully it will 😊
of course you’ll want to change the exact values to suit your needs and server resources.
post_max_size is the size of all files combined, upload_max_filesize is the largest any particular file can be. I’m not aware of anything that prevents them from uploading more than X files in one shot other than just limiting the number of file upload fields in the form (of course someone malicious could create their own html form pointing at your servers if they wanted to).
Dear all here.
I am just trying to cure a file upload problem that I am having via a Standalone Entry Form.
I have access to my php.ini and increased the following in the php.ini: upload_max_filesize 100M post_max_size 300M max_execution_time 800
… but I am still having problems uploading an 11MB file. I also have set a very large file upload preference in the EE File Upload preferences.
And, I contacted my server host and they tested a 20MB file and said it was no problem.
Somehow the server connection bombs out and it is infuriating the life out of me.
I have tested also a 3.5MB file and a 2.5MB. Somewhere in the region of 2MB seems to, on average, upload successfully.
Is there anything I should try here ? Would adding the .htaccess make any difference since I have already changed the php.ini file ?
Any guidance absolutely welcome 😊
