NSM Publish Plus URL Triggers Not Working for Pages Module
IRIS_HQ's avatar
IRIS_HQ
16 years ago
IRIS_HQ's avatar IRIS_HQ
I’ve used the NSM Publish Plus module before with no problems, but am stuck on something this time. The URL triggers /draft , /revision , /preview work fine with content that is accessed through a templategroup/template URL, but they will not work for any URLs that are handled by the built in Expression Engine Pages Module.
EXAMPLE I have a page at: http://www.iris.edu/hq/staff/employee/toigo There is a template group named staff, a template named employee, and toigo is the URL title that brings up the relevant entry from the weblog.
URL triggers work with no problems such as : http://www.iris.edu/hq/staff/employee/55/draft/39/
I have a page at: http://www.iris.edu/hq/about_iris that is handled by the Pages Module. The URL: http://www.iris.edu/hq/about_iris/draft/42/ does not show the draft. I’m pulling these URLs directly from the frame that is used on the publish page with LG Live Look integration
So in summary, the URL triggers work fine for any URLs except ones handled by the pages module. Here’s what I’ve tried and observed.
  1. Changing the Preview URL under the Pages Weblog in the settings for LG Live Look. This doesn’t seem to have any effect on the preview URL generated on the Publish page.
  2. Renaming the URL triggers to avoid an type of collision with similarly named templates.
  3. Going to Edit Preferences for the Weblog that the Pages module uses, going to Path Settings, and then setting the LG Livelook template. This also doesn’t seem to have any effect on the preview URL generated on the Publish page.
Let me know if anyone has any suggestions or has run into anything similar.
