Plugin: Delete Entries
Adam Khan's avatar
Adam Khan
16 years ago
Adam Khan's avatar Adam Khan
Delete Entries lets you easily delete rows from any database table — whether within ExpressionEngine’s database or from any database to which you have administrator access – using an EE template. It helps integrate EE with other MySQL-based systems, such as a commerce platform.
For more information, see the docs.
The plugin costs $5 per EE install, works on both EE v1.x and v2.x, and is free to download and try before you buy.
If however you need to update, insert or view database entries, see the Update Entries ($15), Insert Entries ($15) and Select Entries ($10) plugins.
And if you need all four functions, see the External Entries plugin — at $25 it’s a saving of $20 over buying the four plugins separately.
