Whitespace, Plugin, EE 2.0, Variable set and Logic
BPeddle's avatar
BPeddle
16 years ago
BPeddle's avatar BPeddle
I am working on a plugin in EE2.0
It looks at the url and breaks it out and makes assumptions based on the data on the url segment. I then pass back a word:
try
    switch($this->_type)
    case 'category':
        $this->return_data = trim($this->_type);
        break;
    case 'city':
        $this->return_data = 'city';
        break;
    case 'state':
        $this->return_data = 'state';
        break;
    default:
        throw new Exception('Invalid search type ' . $this->_type);
        break;
In my template it starts with:
{preload_replace:controller="{exp:urlcheck}"}
If I output {controller} it displays the value I expect
I then want to test that value and based on it embed a specific template:
{if controller == "category"}
           {embed="/category"}
      {if:elseif controller == "city"}
            {embed="/city"}
It never seems to match. If I highlight the output of controller and paste it I will notice white space padded on the end. I tried to trim as you can see above but no luck.
Should I be able to test a preload_replace variable like I am, if not is there another solution?
Is this possibly a bug?
Ingmar's avatar
16 years ago
Ingmar's avatar Ingmar
Let me move this thread to “Plugins” for you…
BPeddle's avatar
BPeddle
16 years ago
Oddly enough this conditional works
{if {controller} == category}
I would have assume category is a string and would need quotes.
BPeddle's avatar
BPeddle
16 years ago
Maybe not … getting errors on it now sporadically.
