When I enable the Fieldframe extension and set all the config options, the following snippet stops working.
{exp:weblog:entries weblog="products"}
<li>{title}</li>
{/exp:weblog:entries}Content from exp:weblog:category_heading does show up.
This is even when no field types are enabled and obviously no custom fields have a Fieldframe fieldtype.
Simply disabling Fieldframe makes the output show again. This is a very simple test site with little else going on …
Any idea what could cause this?
[Mod Edit: Moved to the Extensions forum]
Here is a line from my error log
[Wed Feb 03 15:03:48 2010] [error] [client xxx.xxx.xxx.xxx] PHP Warning: Parameter 3 to Fieldframe_Main::weblog_entries_tagdata() expected to be a reference, value given in /www/ldf/htdocs/system/extensions/ext.fieldframe.php on line 238, referer: http://site.com/index.php/products/category/stuff/
Well, here’s your problem 😊
