LG Better Meta Error
Latitude 10's avatar
Latitude 10
16 years ago
Latitude 10's avatar Latitude 10
Hi! I have purchase the LG Better Meta Plugin and somehow it isn’t working! When I enable the extension on the CMS panel, and try to enter to settings it shows me the PHP tags instead of the words it should show. I am attaching an screenshoot of how it looks on my system.
Any help would be appreciate Thanks
P.D. Its almost urgent.
Wouter Vervloet's avatar
Wouter Vervloet
16 years ago
Wouter Vervloet's avatar Wouter Vervloet
Have you dropped the language file in the right place? Looks like you’re missing that one.
Latitude 10
16 years ago
No, I was following the instructions step by step.
I have solve the problem, it looks that my PHP.ini has the simpleTag setting in OFF, and that plugin works only if that option is ON. 😛 A simple change on my PHP.ini and a server restart fixed the problem.
Thanks. 😊
