Well the table channel_data contains the most mystery:
In my case field_ft_3 to field_ft_7 exist but there are no field_id_3 to field_id_7 after that there is field_id_8 which has some data in it and a field_ft_8 which says xhtml.
I understand that field_ft is the format, and the field_id is the value (maybe value would have been a better name 😊 ) but the numbering eludes me. I can probably mess around with it and figure it out, but a description of how it is build would be helpful and would speed things up.
Besides I have a really bad memory so once I have figured it out I’ll forget it if I don’t deal with it for a while and then I’ll have to retrace the id’s again. I would rather just read how it works.
exp_channel_data.field_id_1 contains the data of exp_channel_fields WHERE field_id = 1
Yes that does seem clear enough, if I hadn’t had a list of id’s that didn’t match anything in exp_channel_fields I might have thought of that 😊 It just think that a simple picture that shows the relationships between the tables would be nice.
