extension is not called
Yuri's avatar
Yuri
16 years ago
Yuri's avatar Yuri
Please help me to determine why the extension is not called/working It relies on simple_commerce_perform_actions_end hook
<?php  if ( ! defined('EXT')) exit('No direct script access allowed');
 By: Yuriy Salimovskiy
 http://www.intoEEtive.com
class Deposit_ext {
    var $settings        = array();
    var $name            = 'Deposit extension';
    var $version        = '0.1';
    var $description    = 'Add funds to member\'s account.';
    var $settings_exist    = 'n';
    var $docs_url        = 'http://www.intoeetive.com/';
     * Constructor
    function Deposit_ext($settings = '')
        $this->settings = $settings;
     * Register hooks by adding them to the database
    function activate_extension()
        global $DB, $PREFS;
        $hook = array(
                        'extension_id'    => '',
                        'class'            => __CLASS__,
                        'method'        => 'add_funds',
                        'hook'            => 'simple_commerce_perform_actions_end',
                        'settings'        => serialize($settings),
                        'priority'        => 10,
                        'version'        => $this->version,
                        'enabled'        => 'y'
        $sql[] = $DB->insert_string('exp_extensions',    $hook);
        foreach ($sql as $query)
          $DB->query($query);
     * add funds
    function add_funds( $scobject, $row )
         global $DB, $SESS, $PREFS, $REGX;
                         if ( ! class_exists('EEmail'))
                    require(PATH_CORE.'core.email.php');
                    $subject = 'test subject';
                    $message = 'test message';
                    $MAIL = new EEmail;
                    $MAIL->from($PREFS->ini('webmaster_email'));
                    $MAIL->to('[email protected]');
                    $MAIL->subject($subject);
                    $MAIL->message($REGX->entities_to_ascii($message));
                    $MAIL->Send();
     * No updates yet.
     * Manual says this function is required.
     * @param string $current currently installed version
    function update_extension($current = '')
        return TRUE;
     * Uninstalls extension
    function disable_extension()
        global $DB;
        $DB->query("DELETE FROM exp_extensions WHERE class = '".__CLASS__."'");
     * EE extension settings
     * @return array
    function settings()
        return $settings;
// END CLASS
