Tiny mce will not save
kidsandco's avatar
kidsandco
16 years ago
kidsandco's avatar kidsandco
Tinymce was working the suddenly stopped across the entire site. This is whats its doing.
  • Submitting with the wysiwyg does not add entries to the exp_weblog_data table.
  • The wysiwyg editor doesnt see the exp_weblog_data table to show content in the editor.
  • I checked the relationships across the other tables and they all appear to be fine. Doesnt appear the database got altered.
  • clearing cache didnt solve it.
  • Reinstalled the plugin had no effect.
  • changed the exp_extensions settings field to mediumtext as well from a related post but wasnt the issue..
This is the first time i have seen this happen…
Adam Dorsey's avatar
Adam Dorsey
16 years ago
Adam Dorsey's avatar Adam Dorsey
Hi kidsandco-
What version/build are you running?
Are you using the first-party Tinymce extension? Or a third party extension (ie LG TinyMCE)?
kidsandco's avatar
kidsandco
16 years ago
exp 1.6.8 and using the LG extension.
Ingmar's avatar
16 years ago
Ingmar's avatar Ingmar
Sine these are both third-party offerings, let me move this thread to “Extensions” for you.
