Htaccess generator
gavincooper's avatar
gavincooper
16 years ago
gavincooper's avatar gavincooper
Hello,
I have expression engine installed in a subdirectory “new” on a Godaddy server. Everything seems fine. I can see the homepage, but when I try to create new template groups “about” “story” I can’t view the page in the browser, I receive a page not found.
I am using .htaccess generator to remove the index.php from the URL and I have “about” and “story” added to the file, so in theory they should be viewable.
http://www.streetsweetsny.com/new/ http://www.streetsweetsny.com/new/about/ http://www.streetsweetsny.com/new/story
Control Panel
Secure details removed by Moderator Please do not post any secure details on our forums. I would encourage you to change you control panel password.
silenz's avatar
silenz
16 years ago
silenz's avatar silenz
I urge you to remove your login credentials from the post. AND change your password!
John Henry Donovan's avatar
16 years ago
John Henry Donovan's avatar John Henry Donovan
Thank you for your warning silenz. I have edited your post Gavin and to reiterate I would encourage you to change your control panel password.
